Check Engine light?
Old Mar 4, 2006 | 06:48 PM
jb96audi's Avatar
Default Check Engine light?
Man I just bought a 96 a4 2.8l the other day and then the next day the CEL light came on.. I went to autozone to check it out they said somthing about a EGR valve and gave me a troubleshooting number of P0401 saying somthing like there is insufficient flow in the exhaust gas recirculation system. But everything been running okay...should i worry about this? What should I do? I read another post the other day saying that if you pump ur gas while the car is on that could also happen? is that true or could that be the case? can somone help.....Thanks for the Help
Old Mar 4, 2006 | 08:34 PM
beefski's Avatar
Default RE: Check Engine light?
had the same on my 96 a6. had the cel cleared and has not yet come back. the egr valve, exhaust gas recirculation valve, the vacum lines could be cracked, the valve itself can get fouled with carbon an need a cleaning. it is an expensive part, no matter where online you look. if you do a search on the forum you will find the postings and replies i made when inquiring.
Old Mar 5, 2006 | 10:35 AM
david9999's Avatar
01-76
Output on GST and/or on VAG 1551 scan tool
Possible malfunction cause
Malfunction repair
P0401 / 16785
Exhaust Gas Recirculation Flow Insufficient Detected
EGR system vacuum hose kinked or fallen off
- Check vacuum hoses
Malfunction cause found: Yes
No
- Erase DTC memory, test drive and after test drive, check DTC memory again
MIL Status:
MIL lights up after 2 Trips
Leak in a vacuum hose of the EGR system (e.g. cracked, worn though, etc.)
- Check vacuum hoses for leaks
No
Vacuum hose between EGR vacuum regulator solenoid valve -N18- and mechanical EGR valve plugged
- Check vacuum hoses for obstructions
For troubleshooting Display group 017
No
Continued next page
01-77
EGR vacuum regulator solenoid valve -N18- sticks in closed position
- Check EGR vacuum regulator solenoid valve -N18- page 24-67
No
EGR valve sticks in closed position
- Check mechanical EGR valve page 24-70
Old Mar 5, 2006 | 01:48 PM
a4BRZLowrider's Avatar
i have the same thing on my car...how do iclean the egr valve?
Old Mar 5, 2006 | 01:55 PM
what MIL and DTC memory stands for??
Old Mar 5, 2006 | 01:59 PM
Jestnomen's Avatar
6th Gear
Old Mar 5, 2006 | 06:53 PM
thanks
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
