Check engine light?
Old Apr 12, 2006 | 04:56 AM
A4speed's Avatar
Default Check engine light?
My check engine light has popped up a couple of times recently. Both times it was the same problem, my car was running to lean (to much air, not enough fuel). The last time I filled it up I did only use 88 octane. So I bought a octane booster to hopefully solve the problem. A couple days later, the check engine light came on again saying the same thing. This time I bought a fuel systems cleaner. My question is, if the check engine light comes on again, what would the problem be? New fuel Injectors, fuel filter? Just wanna see what you guys think.
Old Apr 12, 2006 | 04:59 AM
Jeff's Avatar
Zombie Defense Force
Default RE: Check engine light?
running too lean can be caused by many things. FPR, vacuum leaks, injectors, fuel filter... can you give me some more info tho
Old Apr 12, 2006 | 05:01 AM
BadLuckAudi's Avatar
yea we need some more info cuz as of now it could be lots of things
Old Apr 12, 2006 | 05:04 AM
Jeff's Avatar
do you have the code number?
Old Apr 12, 2006 | 05:09 AM
A4speed's Avatar
I don't know now, we erased it . Ok, if it comes up again ill let you guys know.
Jeff's Avatar
ok here are some things for running to lean...
Intake/Exhaust leak
MAP sensor
MAF sensor
Evap canister purge valve
Injecters, fuel pump, fuel filter
Do you have a boost guage? If so what does it read? Or have you noticed any loss in power? if so my guess you have a boost leak after the turbo
Old Apr 12, 2006 | 05:13 AM
A4speed's Avatar
No, I haven't lost any power. It's still good
Old Apr 12, 2006 | 05:19 AM
Jeff's Avatar
next time it comes up get the code and then i can point you in a better direction
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
