check engine light came on...car shakes
Old May 5, 2006 | 06:46 PM
  #21
CaRCrAzY9229's Avatar
Default RE: check engine light came on...car shakes
When i blew a headgasket and had a intake manifold leak my car would shake like hell in low rpms and then smooth out in high rpms but that is pretty major so i dont know just a suggestion. Or maybe a sparkplug is off and in high rpm it doesnt even feel like its missing again just a suggestion
Old May 5, 2006 | 06:49 PM
  #22
apercele79's Avatar
damn its getting serious...thank god im still in warranty (knowing the stealership, i can see them say THE WARRANTY DOESNT COVER THIS PART) or some BS
Old May 5, 2006 | 08:39 PM
  #23
brrman's Avatar
Definitely could be a vacuum leak. That would cause stuttering at low rpm. Hose loose or cracked, broken combi valve, etc... Have to be a bad leak for the CEL to pop on tho.
Old May 5, 2006 | 10:36 PM
  #24
AteUrV8's Avatar
motor mounts??
Old May 6, 2006 | 01:17 AM
  #25
BadLuckAudi's Avatar
im thinkin vac leak
Old May 6, 2006 | 01:36 PM
  #26
JettaRed's Avatar
ORIGINAL: onepoint8tee
All i read was the title of the thread... But Im saying either coil pack(s) or ICM...
Or maf.
That's my vote, as well.
Old May 9, 2006 | 01:32 PM
  #27
apercele79's Avatar
damn you guys are good
i just brought it from the audi service and it was the coil packs
supposedly all the 2003 audi's have an issue with the coil packs and even if the car is out of warranty, the coil packs will get changed at no charge (they had a recall i think)
so when the CHECK ENGINE light is flashing and you lose pretty all all the horsepower, the coil packs could very well be the issue
thanks once again for your help!!!
Old May 9, 2006 | 02:24 PM
  #28
onepoint8tee's Avatar
Im amazed they replaced something that is technicaly out of warranty... I think you got lucky.
Old May 9, 2006 | 02:47 PM
  #29
apercele79's Avatar
well im still in warranty for another 1400 miles....but even if they were out of warranty they would change the coil packs for free only on the 2003s
b/c they had some issue with the 03's
Yurchikrlg
Jun 18, 2011 01:55 AM
parlayin
Feb 10, 2010 12:33 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
