Check Engine Light...no way to tell.....
Old Oct 17, 2004 | 03:36 AM
Soley4pres's Avatar
Default Check Engine Light...no way to tell.....
hey guys
thanks for the last info on the display center.....
so I just got back from a long driving trip in the audi from san fran to los angeles...I pull into my parking spot and low and behold the awful yellow check light comes on....my audi is just over 60000 61200 to be exact...I know there is a 60000 service but what does that intail? and any thoughts on the light? will it go away if I get a tune up? what should I do?
thanks
T. Pres
Old Oct 17, 2004 | 12:06 PM
CRAZYHAWK's Avatar
Default RE: Check Engine Light...no way to tell.....
Engine: On Board Diagnostic: Check Diagnostic Trouble Code (DTC) memory and purge if necessary
Replace pollen filter
This is part of the 60K service
Old Oct 17, 2004 | 12:18 PM
hb972.8q's Avatar
to be able to check and clear codes yourself you can buy a vag-com from ross tech . if you are lucky someone around you has one. it is a great tool to have
Old Oct 17, 2004 | 02:52 PM
Soley4pres's Avatar
Damn those vag coms are expensive...anyone have 1 in the L.A. area that could help me and my audi out?
as always thanks for the posts
T Pres
Old Oct 17, 2004 | 03:48 PM
david9999's Avatar
Follow the bouncing link. vagcom locator
Old Oct 17, 2004 | 09:53 PM
Soley4pres's Avatar
thanks
Old Oct 18, 2004 | 11:31 AM
dudley doright's Avatar
I paid $71 for a Ross Tech clone and it paid for itself 6X when my dreaded check engine light came on.
So, if you own an Audi - owning this diagnostic tool will be priceless.
Old Oct 18, 2004 | 12:59 PM
CRAZYHAWK's Avatar
Do you need a laptop computer for this clone?
Old Oct 18, 2004 | 03:04 PM
yes
Old Oct 18, 2004 | 03:24 PM
Jestnomen's Avatar
6th Gear
obdtool.com Comes with ross-tech's software (unregistered shareware version). Since the software is unregistered, some functions are blocked out and it doesn't give descriptions of all codes pulled. You can register it for 99 bucks though.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
