Chip
Old Apr 25, 2007 | 06:54 PM
akielb's Avatar
Default RE: Chip
well if you go to unitronic.ca they list what appears to be a k03 chip
Old Apr 25, 2007 | 06:55 PM
akielb's Avatar
Default RE: Chip
ok - so you have a major boost leak? software wouldn't just start to produce less - it has to be somthing else
Old Apr 25, 2007 | 06:56 PM
onepoint8tee's Avatar
Default RE: Chip
Ive never heard of anyone running unitronic software on a k03 or k04. I think that is what you should be dwelling on. Sounds like youre in limp mode, and I would guess thats due to an overboost condition caused by a chip designed for a larger turbo than what you have. Do you have a boost gauge? How much boost did you get out of it? Who did your chip installation?
Old Apr 25, 2007 | 06:58 PM
Audi_Skydiver's Avatar
Default RE: Chip
If your at 5 psi you might be in limp mode. Try unplugging your batt and letting it site for a while then plug it back in to clear the computer. Actually scratch that. See if you are getting any codes. If not then try what I just posted.
Josh
Default RE: Chip
ORIGINAL: akielb
Oh my bad... Hmmmm. I still havent heard of anyone using it with a k03/k04 though. Shoulda went with GIAC man
Old Apr 25, 2007 | 07:05 PM
NuYorka103185's Avatar
Default RE: Chip
There site is not very imformative AT ALL! It shows there BT chip setupsbut says its good for any setup. It seems they base it on injector size. Weird!!!
Old Apr 25, 2007 | 07:18 PM
javierh8's Avatar
Default RE: Chip
Josh. I think what you said make sence. It my be on limp mode for producing to much power. The guy at the shop said that the turbo is running at 20 psi
Old Apr 25, 2007 | 07:19 PM
  #18
javierh8's Avatar
Default RE: Chip
the chip was installed by a shop call thirty 20 here in salt lake
Old Apr 25, 2007 | 07:42 PM
  #19
javierh8's Avatar
Default RE: Chip
I just think I am going to get my money from unitronic and get a GIAC chip. What ya all think?
Old Apr 25, 2007 | 07:50 PM
  #20
TDRILL's Avatar
Default RE: Chip
Get GIAC. Reset computer. Do some searching on this forum and make sure that you have all of the correct supporting mods for your setup. If you are running weenee injectors etc and are choking the system, you will have problems with the car running correctly no matter who designed your chip software.
mitch's sline
B7 Models
Oct 4, 2008 07:57 PM
s4noob
9
Jun 24, 2008 02:41 PM
ricehead
Nov 4, 2005 10:59 AM
