chip+KO4 or just KO4
Old Nov 21, 2006 | 12:29 AM
Quarter106's Avatar
Default chip+KO4 or just KO4
ive searched, so need not flame. I was just wondering...
I have a 01 1.8T manny, and i was looking to chip it, Giac preferably.
I am looking to an agressive KO4 in the future.
So should i just jump to KO4 without chip, or would the chip benefit the KO4 setup at all?
thanks alot guys
Old Nov 21, 2006 | 12:35 AM
eurokid's Avatar
Default RE: chip+KO4 or just KO4
chip with the k04 or chip first because your car needs to know you got that bigger turbo on there*...you might also wanna upgrade ur dv because the stock dv wont be able to handle the higher levels of boost
Old Nov 21, 2006 | 12:44 AM
Quarter106's Avatar
so should i chip it first or jump to KO4 software?
Old Nov 21, 2006 | 12:52 AM
eurokid's Avatar
first i installed the giac chip cause i have a tip shift and i wanted my shifts to be faster...then i got the bigger turbo and just had the k04 software added on top of my giac chip. i'd say get it all at once and do it that way
Old Nov 21, 2006 | 12:58 AM
Quarter106's Avatar
i have a stick dude....
so should i get the chip to remove the rev limiter and get the governors removed?
Old Nov 21, 2006 | 01:08 AM
eurokid's Avatar
congrats dude, i was just stating that i didnt get the chip for the bigger turbo at first. <b>k thnx</b>
anyway, the chips whole purpose is to tell your engine that you have a bigger turbo and that things need to be adjusted to accomidate it with things like a/f ratio etc
Old Nov 21, 2006 | 01:49 AM
18T's Avatar
18T
ORIGINAL: Quarter106
first of all get it straight.. to CHIP a car means to get new software for the ecu.
second of all a ko4 will be the same thing as a ko3 if you dont have the proper software.
so YES, you need to get the KO4 SOFTWARE (CHIP) TO BE ABLE TO USE THE FULL POTENTIAL OF THE KO4 UNIT and supporting mods.
If you just put in a KO4 without the proper software, it will be like runing a KO3.
does that make sense to you?
Old Nov 21, 2006 | 01:52 AM
eurokid's Avatar
GIAC [sm=goodidea.gif]
Old Nov 21, 2006 | 02:24 AM
StepUpProductions's Avatar
put in the K04, then build it up with necessary components... (i.e. FMIC, Injectors, Programming)
injectors and programming are the essentials and the FMIC can come later but if you just drop the K04 in you can basically just build on top of it as you go along which is nice...
Old Nov 21, 2006 | 02:30 AM
tractioncontrol's Avatar
