chip+KO4 or just KO4
Old Nov 21, 2006 | 02:31 AM
tractioncontrol's Avatar
Default RE: chip+KO4 or just KO4
If you just put in a KO4 without the proper software, it will be like runing a KO3
Incorrect, it will run lean due to the increased air rate at the same psi level.
Old Nov 21, 2006 | 02:47 AM
18T's Avatar
18T
. think big
Old Nov 21, 2006 | 10:48 AM
eurokid's Avatar
ORIGINAL: StepUpProductions
put in the K04, then build it up with necessary components... (i.e. FMIC, Injectors, Programming)
injectors and programming are the essentials and the FMIC can come later but if you just drop the K04 in you can basically just build on top of it as you go along which is nice...
idk if i'd go with the fmic till like later down the road...more or less you wanna buy a new dv with the k04 then after injectors go for intake, exhaust and then fmic
eurokid's Avatar
Old Nov 21, 2006 | 01:24 PM
Amze's Avatar
Chips are a nice increase, but your the one doing the research... is it a required item in order to make the KO4 run correctly... yes or no? If yes then obviously you need the chip, if no.. then its a personal call.
mitch's sline
B7 Models
Oct 4, 2008 07:57 PM
s4noob
9
Jun 24, 2008 02:41 PM
ricehead
Nov 4, 2005 10:59 AM
