Sponsored by:
Sponsored by:
Clear corner signal bulb
Old 06-29-2005, 02:25 AM
CBing's Avatar
Default Clear corner signal bulb
Is it true that once you do the diy clear corner mod you can paint the orange signal bulb silver and it will still blink orange? If so, what kind of silver paint or spray to use? And is there a clear signal bulb out there that blinks orange? If someone can answer those 2 questions for me I really would appreciate it, thanks in advance.
Old 06-29-2005, 02:30 AM
BFlan2001's Avatar
Default RE: Clear corner signal bulb
yes, just make sure you use a high temp spray paint, and only do one light coat
the bulbs that you can buy are called S-Yo bulbs, and they are pretty pricey (~30 bucks iirc)
Old 06-29-2005, 02:45 AM
CBing's Avatar
Thanks bent
i'll run by an auto store and give it a try in the morning. i cant swing $30 bucks for those s-yo light bulb right now. so one light coat until the bulb is silver will work?
Old 06-29-2005, 03:13 AM
John1.8T's Avatar
Engine Enamel Duplicolor works very well. Its an aluminum color. Just make sure when you apply the paint on the bulb to put a VERY thin layer on it. It goes on pretty thick but just a bit will do the trick. Make sure you mask off the area of the bulb that you are NOT painting too, you dont want to get paint anywhere but the bulb.
I got most of this info from Martini's A4 Mod. Guide - heres the link: http://www.personal.psu.edu/users/r/d/rdm186/a4mods/ lots of nice useful info here.
Old 06-29-2005, 05:29 AM
BFlan2001's Avatar
no problem...just remember to follow the directions on the can (12 inches away)
Old 06-29-2005, 12:59 PM
Jestnomen's Avatar
6th Gear
ECStuning.com provided me with clear bulbs that blink orange when I bought my Ecodes. Might want to give them a call.
wutafobbb
04-15-2008 10:23 PM
audisnut
03-13-2008 04:13 PM
thetryal
05-08-2007 11:57 AM
Jestnomen
03-10-2006 11:09 PM
FezA4
10-15-2005 05:50 AM
Quick Reply: Clear corner signal bulb
