Climate control - compressor
Old Jan 28, 2005 | 12:12 PM
mirela's Avatar
Default Climate control - compressor
Hello, I have a 97 Audi A4 Quattro Turbo with 62,000 mi. I cannot start the compressor in any way:
neither by manually pushing the A/C buton, nor by pushing the defog buton which used to automatically
turn the compressor on. I was told that this is how it works, because outside it's below 48F degrees and the
compressor cannot be started below this temperature. Is this a feature of this model, that I just missed for
the last 8 years since I have the car ? Thanks.
Old Jan 28, 2005 | 12:22 PM
Jestnomen's Avatar
6th Gear
Default RE: Climate control - compressor
Mine will start below 48 degrees. I think it is closer to 32 degrees.
Old Jan 28, 2005 | 12:39 PM
mirela's Avatar
When you say closer to 32F, does that mean that on this model you actually cannot turn the compressor on if the temperature is below
a certain value?
Old Jan 28, 2005 | 02:46 PM
Jestnomen's Avatar
6th Gear
correct, the computer disables the ability to turn on the AC. As soon as you press it, the snowflake will flash but will not stay on.
Old Jan 28, 2005 | 02:48 PM
brrman's Avatar
agreed.
Old Jan 28, 2005 | 03:06 PM
mirela's Avatar
Thank you both very much !
Jestnomen's Avatar
6th Gear
np
dewey527
Feb 27, 2008 04:47 PM
cian_ie
Jan 10, 2007 07:07 PM
quattro/2.8
Jul 24, 2006 06:53 PM
cmars413
Jun 9, 2006 01:59 AM
