Close fuel tank cap!
Old Mar 24, 2015 | 04:10 PM
Hitmanhart89's Avatar
Default Close fuel tank cap!
My 2008 a4 2.0t quatro keeps telling me that I need to close my fuel tank cap. It is closed and I have replaced the cap and also replaced the purge valve as well. Any suggestions on what might be causing this issue would be highly appreciated
Old Mar 26, 2015 | 02:44 PM
rhodes991's Avatar
I had that issue and it was the n80 valve (or purge valve) that cured it. I would guess there is a leak in the system somewhere else. Not sure if it would be between the filler and the tank or anywhere up to the engine. Maybe someone else will have more insight.
Old May 26, 2015 | 07:36 AM
zachary.bark14's Avatar
I am now having the same issue. I also have a check engine light on too. I drove Down to ocean city Maryland and back. The next morning this was happening... Did you guys find a solution? Also, if you don't mind me asking. How much was the n80 replacement?
Last edited by zachary.bark14; May 26, 2015 at 09:56 AM. Reason: additional question
DJmart
Aug 3, 2013 11:08 AM
SasaNG
Apr 7, 2012 11:13 AM
justfixitup
Sep 21, 2009 09:42 PM
beefski
May 1, 2008 12:35 PM
2k S4
Apr 20, 2007 12:07 AM
