clutch pedal noise
Ive search this and came up with no answers so ill ask the question again. When I press the clutch in it sounds like whining noise but goes away when i let off the clutch pedal. The noise is the same noise when you turn your steering wheel all the way to one side.
ORIGINAL: smokeU
power steering pump is what makes the noise when you turn the wheel to one side im not sure about your clutch prob bro.
well i know that its the pump noise but thats the same sound it makes when i press the clutch but it doesnt slip at all
but when a throwout bearing is bad the sound its makes it not even close to the same. when a throwout bearing is bad you will hear pretty loud rattling and when you push the cluth in it rattling goes away
funstuffalex
Apr 10, 2010 10:30 AM
