clutch pedal sticks a wee bit..
Old Jan 25, 2006 | 08:07 PM
juice88's Avatar
Default clutch pedal sticks a wee bit..
when im at a stop on a slight incline, in gear, slowing letting off, the clutch pedal sticks just a little bit then lets off. is there a way i can lube it or something instead of taking it somewhere. i kinda think it only does it when i dont give it much gas, but i dont work the clutch and give it gas at the same time cuz my clutch reeks and its not good for it, says the ppl that put in my clutch. what do u guys think i should do?
Old Jan 25, 2006 | 08:15 PM
techbod's Avatar
Default RE: clutch pedal sticks a wee bit..
The process is so easy that you forget to check the fluid level. Ask an assistant to monitor the lever while you work. Start by filling the reservoir with new, clean DOT 4 brake fluid*. Next place a small, preferably clear tube on the bleed nipple. Put the other end of the tube into a cup partially filled with fluid. Loosen the nipple one turn. Depress the clutch pedal fully and let it return without assistance. Repeat with a few second pause between depressions. Notice the fluid going into the cup. When a solid stream is emitted from the tube without any air bubbles, hold the pedal to the floor and tighten the nipple. The clutch pedal should feel firm and clearly disengage the clutch. If not, repeat the bleeding process. Don't forget to check the fluid level.
[IMG]local://upfiles/12092/A18268C3710446858E82C327A95A6D81.gif[/IMG]
Old Jan 25, 2006 | 08:31 PM
juice88's Avatar
well where do u locate all this crap u are talking about?
Old Jan 25, 2006 | 08:35 PM
techbod's Avatar
on the gearbox mate and a few tips on this link on how and where to find it
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
Old May 31, 2006 | 12:57 PM
damir21's Avatar
i had the same problem, i just put iN STAGE 2 + AND A ALUMINUM FLYWHEEL, and my clutch started 2 grab b4 the release point, i went 2 the shop and they said it's a master cylinder and the slave gotta b replaced. \
what do u guys think?
Old May 31, 2006 | 01:00 PM
techbod's Avatar
try bleeding it first and first off look for leaks in the system
Old May 31, 2006 | 01:06 PM
damir21's Avatar
well i went back to the shop that did my clutch and they bleed it, and they ended up tellin me that those things got to be replaced, is that sumting that u can change on your own without spending $400, and if so are the picture instructions anywhere???
thank you
Old May 31, 2006 | 01:15 PM
techbod's Avatar
same as bleeding the breaks mate and it uses the same filler just locate the slave cylinder on the gearbox and do the same as you would do the breaks and keep the reservoir topped up
Old May 31, 2006 | 01:17 PM
techbod's Avatar
it only needs replacing if its leaking
Old May 31, 2006 | 03:37 PM
north5995's Avatar
You are riding the clutch, and the burning smell is you burning your clutch.
You just need more practice on where the clutch engagement point is and how to engage it quickly on an incline.
zero-o-matic
Mar 18, 2015 05:25 PM
hayman
May 13, 2009 11:38 PM
lectrolink
Mar 25, 2009 12:22 PM
ericcota2003
Mar 9, 2009 10:39 AM
KevinA4
Aug 10, 2007 12:22 PM
