CLUTCH PROBLEM ANY IDEAS?
Old Aug 31, 2005 | 10:30 AM
kingming's Avatar
Default CLUTCH PROBLEM ANY IDEAS?
Lately I have been noticing my clutch pedal is sitting very low, I can actually put my foot under it and pull it up an inch or two with no resistance. I know the clutch is a bit worn b/c it used to pick up high but now I have very little travel in the pedal and have to put it to the floor to engage ion first gear. Up shifting can be achieved w/o using the clutch at any rpm. Also when I was parking last night I noticed a puff of smoke coming from the l/f wheel with clutch depressed. I am wondering if anybody has experienced this or have any idea what this may be. I am thinking a clutch master or the hydraulic slave leaking down? I have this car only a few months and I am not familiar with Audi. The car is a 97 A4 2.8 Quattro. The car has 78k on it and I do not have any service history. Any help? Thanks so much
Old Aug 31, 2005 | 12:29 PM
germancarmaniac's Avatar
Default RE: CLUTCH PROBLEM ANY IDEAS?
check your master cylinder resivor. Audi runs the clutch through this instead of having a seperate hydrolic clutch resivor. You might get lucky and just be low on fluid
Old Sep 1, 2005 | 01:21 AM
kingming's Avatar
I checked the master it is ok. There is also a resivor on the drivers front of the engine compartment that is in front of the ABS pump? I do not know what that is for but it ik also. I put the car up on the lift and pressed the clutch I do not see anything leaking down. I think the slave cylinder might be bad? I figure if i drop the trans i might as well just change the dick, pressure plate, slave and the throw out bearing? Any sugestions before I start this adventure?
Old Sep 1, 2005 | 05:02 AM
flyboy's Avatar
no Idea, but the other reseivor is your power steering.
madman1234509
Jun 5, 2009 04:02 PM
96audia4
Apr 25, 2009 05:56 PM
TKneedsS4
Dec 2, 2007 11:57 PM
Elladara
Oct 4, 2007 01:10 PM
sicc.steez
Jul 20, 2006 02:05 AM
