code po156 from autozone
Old Apr 2, 2005 | 12:55 AM
Jestnomen's Avatar
6th Gear
Default RE: code po156 from autozone
Yeah you can get away with cheapy VW sensors for the 1.8t, but for the 12V there is only the oem part.
Old Apr 7, 2005 | 10:04 PM
ecksman's Avatar
just came from the dealership, they saud there are two o2 sensor after the cat, the scanner at autozone said it was bank 2 sensor 2, does that mean its the passenger side, and which is the easiest way to access it, from underneath or from the inside? do i have to remove my center console?
Old Apr 7, 2005 | 10:10 PM
ImolaS4's Avatar
Underneath.
Old Apr 7, 2005 | 10:15 PM
ecksman's Avatar
so is that the passenger side, do u thinkn i lost some power due to this bad sensor?
Old Apr 7, 2005 | 10:31 PM
Jestnomen's Avatar
6th Gear
Bank 2 = passenger side
Sensor 2 = post cat
Bad O2 sensors CAN cause a decrease in power/efficiency.
Old Apr 8, 2005 | 12:18 AM
david9999's Avatar
Yes, but post converter sensor wont cause much of a change in fuel consumption.
Old Apr 8, 2005 | 12:28 AM
Jestnomen's Avatar
6th Gear
Duh, you're right. The post cat are just to measure the efficiency of the cat, not fuel trims.
ou2mame
Feb 5, 2009 07:08 PM
antonio_A6
May 4, 2008 08:19 PM
johnstef
Dec 9, 2007 07:46 AM
eldrego
Oct 4, 2007 10:51 PM
DiscoStu9
May 12, 2007 01:09 PM
