Codes.
How long have you been geting a code?
You can reset the codes by pulling the neg. battery cable for a few minutes, if you dont have a code reader.
David is saying to inspect/clean the connector on the knock sensor.
I am not sure where they are located for your car.
So, clean the electrical connector, clear the codes, and see if it comes back. Then replace the knock sensor if it does come back.
Hope this is helpful.
A haynes/benlty manual is about the best $15 dollars you will ever spend for your car, you may want to consider that, it will help you locate and troubleshoot your problem.
