Codes.
Old Apr 16, 2007 | 12:44 AM
khj677turbo's Avatar
Default Codes.
Went to discount w/e and had them read the engine codes. Turned up as Knock sensor, bank 2, code po332. What should i do? replace the knock sensor?
Old Apr 16, 2007 | 02:46 AM
Default RE: Codes.
bump
Old Apr 16, 2007 | 10:23 AM
david9999's Avatar
Default RE: Codes.
Easiest thing is to check the wire connections are tight. clear the code and see if it comes back.
Old Apr 16, 2007 | 07:03 PM
Default RE: Codes.
Can someone explain more into detail?
Old Apr 16, 2007 | 07:13 PM
acetrebo's Avatar
Default RE: Codes.
How long have you been geting a code?
You can reset the codes by pulling the neg. battery cable for a few minutes, if you dont have a code reader.
David is saying to inspect/clean the connector on the knock sensor.
I am not sure where they are located for your car.
So, clean the electrical connector, clear the codes, and see if it comes back. Then replace the knock sensor if it does come back.
Hope this is helpful.
A haynes/benlty manual is about the best $15 dollars you will ever spend for your car, you may want to consider that, it will help you locate and troubleshoot your problem.
techbod's Avatar
Default RE: Codes.
[IMG]local://upfiles/12092/6A01B9468C7E4202BC37E6BED587A221.jpg[/IMG]
[IMG]local://upfiles/12092/B3C2412D11D6416EB466BD5F8E033A9F.jpg[/IMG]
Old Apr 16, 2007 | 07:21 PM
acetrebo's Avatar
Default RE: Codes.
Nice, you da man Dave!
Lol, you're gonna put Bently out of business!
Old Apr 16, 2007 | 07:26 PM
techbod's Avatar
Default RE: Codes.
naa they can look after them selves lol
[IMG]local://upfiles/12092/3CBA7C02D8C7469F8DC0FA75D41E70D2.jpg[/IMG]
Old Apr 17, 2007 | 12:46 AM
Default RE: Codes.
That does really help, thanks. But do you know if that code is cleared, that it could potentially fix my backfires, misfires and unsmooth rpm rev range while accelerating?
Old Apr 17, 2007 | 01:23 AM
Default RE: Codes.
I cant seem to find it under that pipe, or the intake manifold, where its highlighted.
