Coilover installation
Old Apr 27, 2007 | 12:30 PM
newyorkgiants44's Avatar
Default Coilover installation
Alright i'm about to buy some coilovers for my 2001 2.8 and I was wondering if any of you have tackled the installation of them... Any tips or know how would be appreciated...
Old Apr 27, 2007 | 12:50 PM
akielb's Avatar
Old Apr 27, 2007 | 01:33 PM
Default RE: Coilover installation
Thank you I appreciate it greatly...
Old Apr 27, 2007 | 01:48 PM
Chewi00's Avatar
Hopping onto the coilover installation bandwagon here.........suggestions on kits? Ive been looking at the KW Variant 1 Coilover Sets.
Old Apr 27, 2007 | 05:29 PM
dafrazi's Avatar
I have installed several setups. Don't follow the audiworld write up for the front. You don't need to remove the pinch bolt on a B5.
Remove the plastic plugs in the engine compartment. loosen the 2 bolts under the plugs almost all the way. Disconnect the sway bar on both sides. Remove the bolt at the bottom of the shock that coonects it to the lower control. Pull the shock fork out and away from the lower control arm so that the lower control arm is no longer between the fork. Then remove the 2 bolts that you loosened and remove the shock.
jogabs
May 1, 2011 07:15 PM
Stevenw83
Dec 2, 2009 12:01 PM
shortyxc
Jul 13, 2009 11:41 AM
MC Hammered
Jun 8, 2007 03:48 AM
TurboQuattroPwr
Sep 11, 2006 11:41 PM
