Cold Start, low RPM Problem - Need Help
Old Jan 25, 2008 | 09:12 PM
rickhsu's Avatar
Default Cold Start, low RPM Problem - Need Help
Need Help!
I have 2007 A4, 2.0T. 30,000 mile. I recentlynoticedtheengine's rpm is about 1,000 when I started my car at very cold morning (outside is 25F). After about 30 sec., the RPM dropped to 800. It was lower than last year winter time. I knew normally, the RPM is around 1400 to 1500during the cold star, and it took atleast 60 seconds to drop down to 800. Canany one give mysomesuggest whatthe problem is. Thanks!
Old Jan 25, 2008 | 09:28 PM
cincyTT's Avatar
I'm make believe
Default RE: Cold Start, low RPM Problem - Need Help
You dont have one. It the 2.0T is like the 1.8T, 1000rpms then down to 800rpms is completely normal. Its the sai (secondary air injection) on and bring the temp of the engine up faster for emissions (you idle less to get up to temp).
Old Jan 25, 2008 | 09:34 PM
rickhsu's Avatar
CincyTT:
If it is normal, then why the previous RPM was much higher than 1000 rpms ? Thanks for your comment ! -- Rick
Old Jan 25, 2008 | 10:26 PM
cincyTT's Avatar
I'm make believe
Dont know. But i wouldnt be to worried. Check the owners manual to see what the correct idle should be. Well it should be in there.
J-mo
Jan 6, 2013 07:47 PM
josearey
Dec 9, 2011 03:05 PM
TT_GUY
Feb 21, 2008 10:26 PM
02A418T
Nov 3, 2006 02:40 AM
LuckyCharmsUXZ
Aug 17, 2006 03:21 PM
