computer reseting itself
Old Dec 4, 2004 | 08:24 PM
brogenville's Avatar
Default computer reseting itself
I guess there must be loose connection or something in my cars wiring, as the central display has taken to coming on and off without reason. I know its not just the display, cos every time it comes on, the computer does a diagnostic check of the car; so presumably there's a loose connection somewhere before this. As it happens, the display comes on more, and for longer periods, after the car has been running for a while, possibly indicating that as whatever loose connection it is is expanding with the car getting warmer.
There's probably a million places where the circuit could be broken, but has anyone else experienced the same problem? Any suggestions would be appreciated.
Cheers.
Old Dec 4, 2004 | 09:27 PM
dudley doright's Avatar
Default RE: computer reseting itself
Check your negative connection on your batter terminals.
Old Dec 4, 2004 | 11:28 PM
Behind the fuse box?
Old Dec 5, 2004 | 01:06 AM
Jestnomen's Avatar
6th Gear
hmm...this could be like finding a needle in a haystack. [:@]
Might want to try removing the instrument cluster and reseating the 3 plugs behind it. The cluster can be removed by pulling off the piece of trim over the steering wheel, then there are two screws to remove.
Old Dec 5, 2004 | 10:54 AM
sounds like a bugger to me.
Leppersmith
Apr 13, 2011 02:48 AM
domino877
Feb 14, 2009 04:59 PM
finatik
Jul 6, 2007 01:01 PM
smokeU
Apr 18, 2006 05:40 PM
thedub
May 30, 2003 06:15 PM
