Condensation inside xenon headlamp
Old Nov 12, 2007 | 01:01 PM
Goonie's Avatar
Default Condensation inside xenon headlamp
As some of you may know I just bought an 04 Avant and I noticed a small amount of condensation inside the headlamp.
Has anyone else had this problem? Is there an easy fix for this? Will this problem eventually burnout my xenon headlight or is the xenon part enclosed seperately inside the headlamp?
Thanks!
Old Nov 12, 2007 | 01:06 PM
cincyTT's Avatar
I'm make believe
Default RE: Condensation inside xenon headlamp
There is a bad seal on your headlights. Your best solution would be to remove the headlight(s) and stick them in the oven or use a heat gun to separate them. Then remove the old sealent and install new sealent, reheat and then press together until cool. That will fix the problem.
Old Nov 12, 2007 | 02:46 PM
01A4T's Avatar
is there condensation on the actual projector glass, or is it on the inside of the plastic lense?You may have a crack somewhere on your housing. If thats the case, then it will probably be pretty hard to figure out where it is. You may have to buy a whole new housing(which are not cheap)
Old Nov 12, 2007 | 03:06 PM
cincyTT's Avatar
I'm make believe
the seal is highly more likely than a crack in the housing.
Old Nov 12, 2007 | 04:35 PM
ultrasport's Avatar
Is the car still under warrenty. I had the same problem and brought it back to dealer and they installed a brand new headlight
morpheous
Feb 18, 2011 10:58 PM
MydKnight13
Nov 28, 2008 05:21 PM
algee007
Apr 27, 2008 03:26 PM
bigears
Mar 12, 2006 07:21 PM
