Control Arms?
Old Jul 14, 2005 | 11:50 AM
VolcanicBlackA4's Avatar
Default Control Arms?
How can i tell if my control arms are bad? I have heard about the service recall on them, and when i start the car and turn the wheel i hear creaking, but only for about 10 seconds then its gone. what can i do to check? thanks
Old Jul 14, 2005 | 01:31 PM
BFlan2001's Avatar
Default RE: Control Arms?
if it's more of a whining sound that is your power steering pump...let the car idle for a few seconds before you turn the wheel to let the fluid get flowing...to check your control arms just press down on each corner of your car and listen for a squeaking sound (brrman has an excellent way of describing it: like two balloons rubbing together)
Old Jul 18, 2005 | 03:50 PM
laxhuskie9's Avatar
Another way you can tell if your control arms are bad is when you go over smaller bumps and such goin like between 5-15 mph..you'll hear a rattle. Generally it's a control arm. I just had 2 of mine replaced but the ones that are recalled are ONLY the FRONT LOWER control arms.
Old Jul 18, 2005 | 03:54 PM
headshok2002's Avatar
yeah the recall is a bit of a joke...
before you buy any parts from the dealer, be aware that meyle makes kits, that go on ebay for 500USD... for all 10 pieces. The dealer wants double that, I believe.
If it's happening when you turn, and its a "creaking" (clickling???) that could be a CV joint, but it wouldnt/shouldnt go away.
Old Jul 18, 2005 | 04:13 PM
brrman's Avatar
Old Jul 18, 2005 | 05:11 PM
STEVE36's Avatar
I would guess a wheel bearing first. Sounds like it's happening at lower speeds.
Or possibly very slight pad/rotor contact that makes a quiet squeak at really low speeds. Especially after being sitting for a while.
Steve
Old Jul 18, 2005 | 05:42 PM
brrman's Avatar
Steve suggested some good possibilities.
Push down on the fender of the car to compress the suspension.
If it creaks it is either the control arms or the tie rod ends. No doubt.
And you should only hear the clicking of a CV joint if you are moving while turning.
jdahlen24
Aug 25, 2011 09:50 PM
jdahlen24
Aug 25, 2011 03:05 PM
audiboy31790
Aug 20, 2008 11:07 PM
Tonyd
Aug 10, 2005 09:33 PM
Tonyd
Aug 9, 2005 01:02 AM
