Control Arms/Timing Belt
Old Aug 8, 2006 | 11:31 AM
VolcanicBlackA4's Avatar
Default Control Arms/Timing Belt
My question is are these jobs fairly easy to DIY? I need to replace the lower front control arms and the timing belt. Wa looking at the kit from ECS tuning. Is there a cheaper place to go for them? Also, what tools will I need for the jobs? Thanks for the help.
Old Aug 8, 2006 | 12:18 PM
smokeU's Avatar
Default RE: Control Arms/Timing Belt
search for timing belt DIY. it takes time and tools but can be DIY depending on how mechanically inclined you are. not that I would know cause I would never attempt it but thats what i've heard by reading/searchiing.
Old Aug 8, 2006 | 02:03 PM
acetrebo's Avatar
Timing belt difficulty: probably a 7/10
Control arms difficulty : 7/10
Oil change: 2/10
timing belt is not too bad, just takes a lot of time to take everything apart and get to it. Once you do, its not to hard to change it, just need to take your time and be careful, and check everything over good.
I say go for it if you are handy with a wrench, you don't really need special tools other than a small swivel socket. (depends on your year /model).
May of us on this forum have done it and can give advice if you get stuck somewhere. Just get one of the write-ups form audiworld, and read it over. If you feel comfortable with the write up on it, then you will have no problem doing it.
It took me a total of about 12 hrs on mine, probably slower than most. I spent extra time making sure all the cams were aligned because my belt had jumped a bit.
Old Aug 8, 2006 | 04:09 PM
thanks for the advice...is ECS tuning a good place to buy from?
Also, wondering if i need a torque wrench
Old Aug 8, 2006 | 04:27 PM
Mike@PureMS's Avatar
We've got timing belt kits available as well. Check out our website or shoot me an email if you have any questions.
Old Aug 8, 2006 | 05:00 PM
clconversion's Avatar
depends on where you are from if you are up in Canada let me know I sell the 12 piece control arm kit with tie rods for $550 CDN
Old Aug 8, 2006 | 07:32 PM
acetrebo's Avatar
ORIGINAL: VolcanicBlackA4
Yep. Also Check Pap-parts.com, I bought mine there cause it was even cheaper, but they are local for me so I went there and picked up the kit.
crosswire
Feb 13, 2008 02:36 PM
Slowb5
Sep 4, 2007 10:10 PM
