coolant temp sensor
Old Dec 21, 2005 | 03:24 PM
kingming's Avatar
Default coolant temp sensor
I have a 97 a4 q with a 2.8l does anyone know where the coolant temp sensor is located apparently you need to pull it out and match the connector color? if anyone can help. Thanks
Old Dec 21, 2005 | 04:03 PM
flyboy's Avatar
Default RE: coolant temp sensor
If I'm not mistaken there are two. one is for the fan and the other is for the guage The one for the fan is on the rad. core left side.. I don't remember where the other one is thou.
Old Dec 21, 2005 | 08:26 PM
kingming's Avatar
YEA I THINK I NEED THE OTHER ONE I AM GETTING A CODE FOR IT AND THE BENTLY BOOK SAID BEHIND THE RIGHT HEAD BUT I CANT SEE IT
Old Dec 21, 2005 | 09:38 PM
Slowb5's Avatar
hey, um....the caps lock key is about 1/16 of an inch to the leftfrom the A key.
just a friendly reminder to not type full posts w/ the caps lock key on.
Old Dec 21, 2005 | 11:22 PM
kingming's Avatar
Yea thanks for your input captin obvious I will remerber to do that
Old Dec 22, 2005 | 05:21 PM
brrman's Avatar
Should be behind the head green or blue color, sticking straight up from a coolant hose. It has an electrical plug on the other end.
Looks like one the pic below
[IMG]local://upfiles/359/A19977ADF65A465C8B5F610450CA64FA.jpg[/IMG]
[IMG]local://upfiles/359/EA122D58BCE04223960EF7FEB388DB0C.jpg[/IMG]
Old Dec 23, 2005 | 11:40 AM
kingming's Avatar
Thanks for the help! I go the sensor out last night and put the new one in, cleared the codes and it seems ot be fine. however every now and then the car seems to stublel at idle and then stall out once in a while. I was thinking the idle control valve but wouldent that set a code? Any ideas? Thanks agin for your help
burak
Oct 23, 2009 07:21 PM
dhenson2342
Mar 14, 2009 08:04 PM
JL AUDI
Mar 9, 2006 01:38 PM
