cooling fan
Old Aug 26, 2007 | 01:14 PM
chefmango's Avatar
Default cooling fan
finished timing belt installation, started right up (thank you forums for some invaluable info) however the mechanical cooling fan is not operating. Belt tension is good, pulley is spinning like a top, but I can hold the fan blades as if the clutch is not engaging. do those mechanical fan clutch assemblies go bad or did I miss something in the re-assembly like a lock key or whatever?
JD_MILLS
May 16, 2012 06:29 PM
LKaler
Jul 26, 2010 11:38 AM
devolab
Aug 13, 2009 02:51 PM
ditallow
Mar 31, 2008 06:16 AM
jgm7507
Oct 31, 2007 07:33 PM
