Cornering affecting coolant???
Old Nov 27, 2005 | 03:48 PM
dlinbh's Avatar
Banned
Default Cornering affecting coolant???
Whenever I take my 97 A4 1.8T on a fast corner I get a warning signal beeping from the electronic dash readout which flashes the coolant symbol warning. Can ANYONE explain why I am having this problem? Should I be getting my coolant checked or something?
Also, whenever I press the check car button (same as clock button) to check my car, the check goes through fine with no warning about coolant. Help please. Thanks for your time.
Old Nov 27, 2005 | 04:01 PM
AudiTech04's Avatar
Default RE: Cornering affecting coolant???
Is the coolant low in the tank
Old Nov 27, 2005 | 04:03 PM
dlinbh's Avatar
Banned
let me check. meanwhile can anyone give me advice on how to fix if coolant is low? Where to buy from? Dealership?
Old Nov 27, 2005 | 04:12 PM
AudiTech04's Avatar
Yes get it from the dealer
As for fixing it, look for leaks
Old Nov 27, 2005 | 06:05 PM
bhj0887's Avatar
My 96 does it every now and then. It doesn't leak or isn't low and will only do it on a fast hard corner or if I'm playing a little too hard in the dirt.
Old Nov 28, 2005 | 08:24 PM
dlinbh's Avatar
Banned
now it does it when im taking a corner at about 40. My question is: Is the Audi's coolant supposed to last the entire life of the car? Or will the coolant of all cars run low at some point after so many miles?
My 97 A4 has 120k on it. Should I be looking for a leak? Or is it possible that after my mileage it is just running low?
Old Nov 28, 2005 | 08:43 PM
techbod's Avatar
coolant should be checked as often as possible (water evaporates with heat) and changed every 2 years with a 50/50 mix antifreeze
Old Nov 28, 2005 | 11:41 PM
BFlan2001's Avatar
your coolant level is probably a little low. you'll have to get it from a dealership or euro tuner shop. make sure you get "G12" coolant.
suky321
Nov 23, 2012 07:29 AM
shortyxc
May 2, 2011 12:03 AM
brncoboy
Oct 18, 2007 03:47 PM
ryandlor
Feb 10, 2007 01:57 AM
AudiGirl80
Apr 29, 2005 02:39 AM
