correct boost readings?
Old Nov 21, 2007 | 05:30 PM
limptimtim's Avatar
Default correct boost readings?
i have a '99 1.8T a4 tip with K04, dv 710n, giac chip.
I finally got around to installing a boost gauge and it is only reading 18in. vacuum at idle and spiking at 14-15 PSI
awe-tuning said i should be seeing 20-25 in. vacuum at idle and spike around 18-19psi with this setup that i have
i checked for boost leaks and can't find any. what are other areas of problem that might be causing the small numbers? are these numbers that awe-tuning provided correct?
thanks
Old Nov 21, 2007 | 05:34 PM
Papachristou's Avatar
Default RE: correct boost readings?
could be your DV, when i got my 1+ i was spiking 23, holding 20 then my DV broke and i could only spike 18, hold 15
Old Nov 21, 2007 | 05:49 PM
limptimtim's Avatar
my exhaust is stock...i shouldn't expect as high of readings as you mention should i..or is exhaust not much of a factor in boosting?
ThatRetardedKid
Aug 10, 2016 01:16 AM
Sheasta
Apr 28, 2012 02:44 PM
doj
Mar 15, 2010 07:52 PM
98A4TQ
Apr 6, 2008 06:01 PM
Philthykins
Mar 17, 2007 04:19 PM
