couple of things...need help!
Old Sep 1, 2006 | 08:41 PM
Dunzie182's Avatar
Default couple of things...need help!
ok so i put in a manual boost controller in a couple of days ago, since then ive been trying to work with it, but it will not allow me to boost over my chipped boost level of 15 psi. it will only allow me to go down. i finally got fed up with it and took it off. i hooked my n75 back up but now im in limp mode...any reason why this would be? also is there a quick fix besides clearing the codes?
Old Sep 1, 2006 | 09:21 PM
aRIf's Avatar
Default RE: couple of things...need help!
you already have 201 posts.... You should have known the answer already... Search it before the "New" mods see you
Old Sep 1, 2006 | 10:05 PM
Jeff's Avatar
Zombie Defense Force
o snap what should a new mod dooooooo????????
Old Sep 2, 2006 | 01:08 AM
Dunzie182's Avatar
yeah i already know to disconnect the battery for 15 minutes, but that never works for me. i didnt know if there was some other method to fixing it
Old Sep 2, 2006 | 01:21 AM
Jeff's Avatar
the reason it wouldnt let you over boost is because you probaly had it wrong
did you ahve it hooked up like this?
[IMG]local://upfiles/4588/F32E61F5AC63424E9C45953E535F269F.jpg[/IMG]
Old Sep 2, 2006 | 01:51 AM
BaconBait's Avatar
What MBC did you get?
Old Sep 2, 2006 | 03:21 AM
Dunzie182's Avatar
yes i had it hooked up right...but when i had it set at the minimal level it brought my boost back to stock. it was very weird so i gave up on figuring it out. and it was a turbo xs single stage boost controller
Old Sep 2, 2006 | 04:22 AM
FezA4's Avatar
Yo I have absolutely no idea what the answer to this problem is but I just wanted to comment on how insanely awesome Jeffs intricate diagrahm of the setup of the MBC to the turbo is. The detail is just overwhelming.
Old Sep 2, 2006 | 12:53 PM
Bondga's Avatar
ORIGINAL: Dunzie182
It brought it back to stock because stock is the minimum amount of boost that your turbo can produce. YOu cant run a turbo with no boost(I don't know why people think that) the lowest you'll probably ever see aturbo be is 6.5lbs unless you turbo is the size of a Hotwheels tire. Also as far as going over the chip amount. This guy i know(he drives a GTI with the same engine 1.8T) was tellinme sumtin about how an MBC can only produce like 14lbs a boost on our engine, it was sumtin like that i wasn't really listin and i dont really know if he knew what he was talkin about but its a though.
Old Sep 2, 2006 | 05:44 PM
Jeff's Avatar
ORIGINAL: Bondga
ORIGINAL: Dunzie182
ok your mostly right. the reason you cant bring a turbo to 0 psi is because the wg is set to open at 6.5psi. it wont open anylower unless you take it apart and mess with it but who wants to run low boost???, what the mbc will trick the wg to think its not getting any boost. but when you hit the boost you have your mbc to open at it pops open and shoots all that boost to the wg and the wg will then open preventing overboost. if you hook the mbc up right then you can get over 14psi. i ran mine at over 23psi and blew up the turbo. yes i was retarted and should of used the search function but that was a noob mistake and im lucky i did blow the motor becuase looking back at my dyno's i was very very scary lean[:@]
Oldschooltuner
Sep 20, 2011 11:47 AM
DankesterA4
Sep 28, 2009 07:58 AM
SHAYs4
Oct 2, 2008 03:27 PM
Mya4T
Feb 9, 2008 08:33 PM
melam
May 18, 2005 06:08 PM
