couple of things...need help!
ok so i put in a manual boost controller in a couple of days ago, since then ive been trying to work with it, but it will not allow me to boost over my chipped boost level of 15 psi. it will only allow me to go down. i finally got fed up with it and took it off. i hooked my n75 back up but now im in limp mode...any reason why this would be? also is there a quick fix besides clearing the codes?
the reason it wouldnt let you over boost is because you probaly had it wrong
did you ahve it hooked up like this?
[IMG]local://upfiles/4588/F32E61F5AC63424E9C45953E535F269F.jpg[/IMG]
yes i had it hooked up right...but when i had it set at the minimal level it brought my boost back to stock. it was very weird so i gave up on figuring it out. and it was a turbo xs single stage boost controller
Yo I have absolutely no idea what the answer to this problem is but I just wanted to comment on how insanely awesome Jeffs intricate diagrahm of the setup of the MBC to the turbo is. The detail is just overwhelming.
ORIGINAL: Dunzie182
It brought it back to stock because stock is the minimum amount of boost that your turbo can produce. YOu cant run a turbo with no boost(I don't know why people think that) the lowest you'll probably ever see aturbo be is 6.5lbs unless you turbo is the size of a Hotwheels tire. Also as far as going over the chip amount. This guy i know(he drives a GTI with the same engine 1.8T) was tellinme sumtin about how an MBC can only produce like 14lbs a boost on our engine, it was sumtin like that i wasn't really listin and i dont really know if he knew what he was talkin about but its a though.
ORIGINAL: Bondga
ORIGINAL: Dunzie182
