Cruise Control Problem...NEED HELP!
Ok, my cruise control works fine most of the time but at times when I am driving and have it set, it will just automatically turn off and then I try to re-set it but it doesn't work still. It stops working at times for some odd reason here and there. Let me know what you think the problem is. THANKS!
I had this exact problem and fixed it myself. The cruise control module is above the glovebox behind the dash. To repair mine I re-soldered half the circuit board starting with the connector end and worked my way up until it was working again. Not hard to do if you have some skill at soldering, if not then just pick up a new cruise control module off ebay or a salvage yard.
