custom exhaust ???'s
UNLESS you were planning on running a bigger turbo or a lot of boost later in the future.
You probably wont notice the power difference from a 2.5-3in. Especially if you run an extra (particularly chambered muffler) on it. I would say running a cat all the time, a straight through resonator/muffler such as a magnaflow (eliminates the high tones), and a chambered muffler, such as a turbo muffler.. Or for looks the chambered muffler then a fart can round straight through..
either way you will get plenty of back pressure from a cat and 2 mufflers..
Good luck
Andrew
Good luck
Andrew
Since your question is answered, its got me thinking now about my setup/future setup. My milltek system is 2.75" from the down pipe back. So I retain my stock DP and cat. When I put on my 3" test pipe, its going to be 3" TP - 2" (stock) DP - 2.75" Milltek resonated. I wonder what thats going to do for my performance....? hopefuly not bad things..
ORIGINAL: swift_A4
i would go 2.5in with res and muffler both straight thru's should be sufficient.
well i think he dp stock is 2.25 but its not gunna really hurt anything, thats how I ran my set up and no probs
ORIGINAL: onepoint8tee
Your performance will increase one8, Miltek did testing showing the 2.5 inch downpipe was best for the 2.75 exhaust for maximum power from the quttro system, so I would imagine the 2inch will be fine or you could get a $30 downpipe made in a 2.5 inch. They told me notto go any larger than a 2.5inch downpipe with the stock turbo but if I ran a large turbo to switch to a 3 inch downpipe with the 3 inch testpipe and a 2.75 exhaust.
LaneKeenan47
Sep 26, 2006 04:13 PM
