The dealer can't work on my car, and doesn't know why.
Old Mar 12, 2007 | 07:47 PM
The Bishop's Avatar
Default The dealer can't work on my car, and doesn't know why.
I just got my car back from the dealer, (took it in cause it's in limp mode and I can't read the codes). Well seems that they can't communicate with the ecu either, and have no idea why. Anyone ever heard of this? and is my car totally f***ed? I know the turbo is bad so I have a k04 on order, but if that doesn't work I might have to burn the car.
Old Mar 12, 2007 | 07:51 PM
acetrebo's Avatar
Default RE: The dealer can't work on my car, and doesn't know why.
Maybe you need a new ecu? Do you know anyone you can swap ecu with to test it?
Or is something wrong with the wiring for the OBDII connection? You'd think the dealer could figure something out.........
Old Mar 12, 2007 | 07:55 PM
The Bishop's Avatar
Unfortunitally I don't know anyone else with an A4. And I'm hoping it's the wiring to the connector port, although that leaves a whole bucket of problems aswell.
Old Mar 12, 2007 | 07:59 PM
acetrebo's Avatar
Where are you located? There's got to be someone in your vicinity.....
Old Mar 12, 2007 | 08:00 PM
The Bishop's Avatar
Fort Collins, CO. if there is anyone near me please help.
Old Mar 12, 2007 | 08:03 PM
akielb's Avatar
check out ebay - you can always pick up a used ECU - sometimes its already chipped!! Good luck
Old Mar 12, 2007 | 08:06 PM
onepoint8tee's Avatar
I know this sounds sketchy.. But if you cant get any local willing help, see if you can test drive an a4 for sale with same yr/engine code/tranny and swap the ecu's to see what happens. Its not difficult to remove the ecu, and its technicaly not being dishonest or anything... You might want to drop the knee pannel and look at the wiring to the OBD port first to make sure no wires came loose... Did the dealer try that?
Old Mar 13, 2007 | 02:25 AM
aznknites's Avatar
I had a problem with my VAG after i installed a iPOD ICe unit into the car...
For some reason the CD Changer controller part was messing with the VAG..
Old Mar 13, 2007 | 02:29 AM
Lazer Viking's Avatar
after market head unit installed incorrectly perhaps ?
Old Mar 13, 2007 | 03:03 AM
The Bishop's Avatar
I disconnected my head unit, and no difference trying to use my vag.
