Is the dealer giving me some BS
Old Dec 14, 2006 | 03:42 PM
dsalomone's Avatar
Default Is the dealer giving me some BS
OK so i just bought this 2001 2.8 A4 quattro 70k. The Oil Min light came on. I brought it back (to the dealer) and he said it was slightly low so he filled it and i left. I reported the same thing so he did a dipstick test. He marked the dipstick and i brought it back 1000 miles later. He said it was ok and that i might have to add a quart here and there. So this has happened 1 more time since then, so i added a quart. So what gives? If the oil is supposed to be changed every 10k, why does the min light come on every 3k or so. He tells me its not burning oil, but where is the oil going? Does anyone think its normal. Any similar situations or comments would be appreciated...thanks
Old Dec 14, 2006 | 04:08 PM
kristokes's Avatar
Default RE: Is the dealer giving me some BS
Take it to another mechanic and see what they think. I don't think you should be re-filling your oil every 1k miles.
Old Dec 14, 2006 | 04:36 PM
GermanAutowerks's Avatar
We've had problems with turbos seeping out oil, but yours is a 2.8.
A, from a independant shops point of view, i would recommend changing your synthetic every 5,000 miles. 10,000 miles just leaves too much room for sludge issues to happen.
B, take it to a well respected independant shop in your area. The misconneption is that dealer mechanic know everything about your car, but in reality, we have had both a dealer mechanic, and an independant mechanic working for us, and all the dealer mechanic wanted to do is replace things, rather than repair things.(no offense to any respectable dealer mechanics out there)
I beleive that you will be much more satisfied with an independant shop because their lives depend on it. Dealers dont have to care about peoples cars, because it does not effect them in any way. You'll also notice that the charges are MUCH less expensive.
C, If you are still under warranty and oil leak would be covered in your warranty, tell them that you they have to repair your oil leak, or you will report it, and if they do not repair the leak in 3 tries, they legally have to buy back to vehicle.
Thats just my 2 cents. Hope it helped you
Old Dec 14, 2006 | 05:12 PM
dsalomone's Avatar
thanks guys.
Old Dec 14, 2006 | 05:22 PM
ComingSoon's Avatar
definitely should not be adding oil that often. if your burning oil that fast you may not be using the right oil for your car. unless there is a slow leak you cant see under the car, gasket, pan, filter, or block. recommended motor for you car and model below. good luck!
Lubro Moly Voll Synthese Fully Synthetic
(Mfg. Germany)
German Lubro Moly fluid for Audi VW. Fully synthetic, energy conserving (fuel economy) SAE 5W-40 motor oil for the latest engine concepts (both gas and diesel), such as multi-valve arrangements, variable cam and timing configurations, turbo charging, supercharging, intercooling, etc. Saves fuel, provides instant lubrication after a cold start. Good for extended oil change intervals and highest demands. With letters of approval from BMW, Porsche, and Audi VW.
or
Lubro Moly MoS2 Antifriction Super
(Mfg. Germany)
German Lubro Moly fluid for Audi VW. This is the classic special oil favored by demanding German car owners for that extra measure of protection and trouble-free operation for high class cars. Contains the right amount of MOS2 for optimum wear protection and friction reduction. The oil itself is blended from a hydrocrack base oil and selected additives to the level of API SH. It is an all-season motor oil for the most stringent demands.
Old Dec 15, 2006 | 10:55 PM
krazpony1's Avatar
If you do alot of downnshifting it will go through oil. I had that problem.
Old Dec 16, 2006 | 06:20 AM
18T's Avatar
18T
change ur oil every 5k miles not 10k if you change ur oil every 10k miles youre bound to have problems . and those 2.8's burn some oil. also have you checked for leaks?
Old Dec 16, 2006 | 07:04 AM
duburban's Avatar
I have a 2.8 30V with 150k+ miles. Just so you know, the dipstick is only reading 1 quart. If you check it just after you drove it, the oil will be up in the engine and need a few min to seep back in. With higher compression ratios, modern engines burn more oil. I've researched this topic and found that many cars, Mercs, Audis, VW, etc... burn 1 quart between changes. My engine burns less than or about 1 quart between 4k mile oil changes. Try reading the oil yourself to really understand whats happening. From what i understand this engine will burn oil naturally, but not an excess of it. Personally i think your car is fine. Independent shop is crucial.
Old Dec 16, 2006 | 01:06 PM
CRAZYHAWK's Avatar
Use one of the following engine oils:
https://www.audiforums.com/m_16044/tm.htm
If you park in the same place every night, check
the ground for leaks.
sgt_cr
Mar 31, 2015 04:02 AM
Jchockey100
Mar 6, 2012 09:28 AM
dsalomone
Dec 15, 2006 10:55 PM
Amze
Nov 24, 2006 01:48 AM
