Did anyone ever change transmission fluid??
Old Sep 16, 2004 | 01:38 AM
Jestnomen's Avatar
6th Gear
Default RE: Did anyone ever change transmission fluid??
I'm starting to wonder about how my mechanic changed my tranny fluid. He removed the hoses from the tranny cooler lines and circulated in new fluid from there.
Old Sep 16, 2004 | 02:17 AM
mikehh's Avatar
Hmmm, but then how do you know when you have reached the exact level?
I would really like to save some bucks, rather than paying a fortune for something that could be done at home.
Old Sep 16, 2004 | 02:57 AM
SlimChriz's Avatar
well the way you check if its the right level is by bringing the fluid up to said temp and removeing the plug in the....aahhh...check hole then when the fluid slowly drips out its full...
Yes I already bought the filter but when ordering I forgot to refresh the page er sumthing because the fluid never made it onto the invoice Ill get the fluid eventually really I will...
Old Sep 16, 2004 | 06:06 AM
brrman's Avatar
I had mine changed at the VW dealer. Cost was $117.
Old Sep 16, 2004 | 08:09 PM
mikehh's Avatar
Is that inl. everything?? Just gor the quote from the Audi STEALER ( I like that!!) for $250.
Old Sep 17, 2004 | 12:15 AM
david9999's Avatar
117 sounda about right for the dealer to drain and fill.
That sounds cheap for having them drop the pan, change the filter and replenish the fluid.
As I recall, the correct fill is when it just drips out when the engine on . Fill it up then turn on the car and run the transmission through the gears ending in park. This will suck up some fluid and fill again until it just dribbles out.
Put the check plug back in BEFORE stopping the engine, otherwise the fluid in the torque converter will pour out as will lots of transmission fluid.
virtualelvis
Nov 27, 2024 06:32 PM
pointman0853
B7 Models
Nov 26, 2009 07:29 PM
ride159
Oct 16, 2007 11:21 AM
jason23silver1
Sep 12, 2007 05:04 PM
cireecnop1
Feb 15, 2006 04:16 PM
