did a search, question about chipping automatic
ok, my roommate is getting a 2003 a4 1.8 avant with tip tonight with less than 15,000 miles on it. She's coming from a V8, and she's looking to add some more power to the 1.8. I know if she gets her ECU chipped she has to upgrade ther DV and that the tip chip reduces shift time to .2 seconds, but I need some clarity on other issues regarding chipping and auto.
1. Can an automatic handle the extra boost from the chip? I read a post that a torque converter blew once the chip was installed.
2. I also read that it's prudent to get a tip chip as well, what are the consequences if she only chips the ECU?
3. Finally, I read that there is a possible problem with the CEL when getting an ECU and tip chip. Aren't the 2003 a4's prone to electrical problems, is this something I should be worried about?
Thanks guyz appreciate the help.
1. From a basic chip yes, she will be fine. If she wants to upgrade to a larger turbo, then she will want to think about Level10 upgrade for the tranny.
2. You do not need a tip chip at all. I have had 2 automatic chipped cars without the tip chip. It is nice to have, but not necessary if you have the ECU chip.
3. Never heard of this problem. But then I am no expert on the b6's.
Whoever says Audi's are prone to electrical problems doesn't really know them that well. We rarely see those kind of problems arise on the forums. I don't know why they have this stigma.
CEL after chipping/tip chip? Never heard of that one.
The only reason you would want/need a tip chip is to reduce the lag between shifts. It is not necessary, but you may want it. reduces shift by ... .8? if so thats 5x.8 = 4 seconds in 5 gears... will hinder 0-60 times a little....
My suggestion ECU chip it ....
get the tip chip is you ever feel like it...
It will not hinder 0-60 times. It will improve them.
ORIGINAL: InsaneHatter
