Difference between suspensions?
Old Mar 26, 2006 | 05:23 PM
kozhockey4's Avatar
Default Difference between suspensions?
Is there a difference betweeen the stock S4 suspension and the stock sport suspension of the A4....B5 models.
Old Mar 26, 2006 | 06:28 PM
A4 the Quattro's Avatar
Default RE: Difference between suspensions?
yes
Old Mar 26, 2006 | 06:34 PM
kozhockey4's Avatar
what is the diff? is it lower at all? Its probably stiffer right?
Old Mar 26, 2006 | 08:12 PM
Karl's Avatar
the S4 is about 300lbs heavier so yes the springs are stiffer
Old Mar 28, 2006 | 03:39 PM
kozhockey4's Avatar
so how would the S4 suspension look/ride on a 98 A4 2.8Q??
Old Mar 28, 2006 | 10:03 PM
toaster's Avatar
why would you go out of your way to confuse yourself with s4 suspension?
there are lots of suspension setups you can run designed for the a4. some are stiffer than others.
just look into a4 kits so you don't need to worry if there's a problem or not.
doesn't that make sense?
Old Mar 28, 2006 | 11:07 PM
kozhockey4's Avatar
my buddy is getting rid of his s4 suspension and would give it to me cheap. it was there as an option and i was just wondering about it is all.
heezy
Jul 18, 2014 11:52 AM
laoma
Jan 26, 2012 12:22 PM
jisungoppa
Jul 6, 2009 09:58 PM
bigrig
Feb 8, 2009 11:48 PM
audipavi
Feb 7, 2008 08:26 PM
