Differential Seals
Old Aug 5, 2007 | 09:50 PM
lboudreau's Avatar
Default Differential Seals
I have a 98 A4 2.8 that has a slight leak comming from the rear differential. It seems to be comming from the right shaft. Could this be as simple as a seal? How much does it usualy cost to get the seals on both sides replaced? Any help would be greatly apreciated!
Old Aug 5, 2007 | 10:00 PM
wood_e's Avatar
Default RE: Differential Seals
I was quoted $300 to fix my seal - needless to say it's leaking... Just top your diff fluid off every year and you'll be fine for a LONG time.
Old Aug 5, 2007 | 11:05 PM
lboudreau's Avatar
So you're sayingthat unless the fluid starts to pool on my driveway, I should be ok just topping it up? Was you're quote from a dealer?
Old Aug 5, 2007 | 11:27 PM
wood_e's Avatar
No - that was from an independent shop. I would never go to the dealer...
Topping it off should be fine. Maybe changing it out yearly too...
BaseDrifter
Feb 28, 2015 11:50 PM
audib5a4
Feb 6, 2014 07:50 PM
Pitao
Sep 18, 2013 09:59 PM
gwos25
Nov 10, 2009 01:08 PM
curtisimo
Nov 5, 2009 12:06 PM
