DISCONNECTING THE BATTERY.
Old Mar 28, 2006 | 05:08 PM
Alexa4's Avatar
Default DISCONNECTING THE BATTERY.
Hi, I just wondered because my battery is 'on it's way out' is it safe to disconnect it and replace it with a new one? just i read somewhere doing this would reset certain settings within the cars electronics and compuers, thanks for your replies
Old Mar 28, 2006 | 11:38 PM
Jestnomen's Avatar
6th Gear
Default RE: DISCONNECTING THE BATTERY.
Yeah it will reset the radio most likely. Make sure you have the "safe code". It is typically located in the owners manual. Also the car may run rough for a few hundred miles while the ECU readapts.
Old Mar 29, 2006 | 12:46 AM
mjvss21's Avatar
make sure you reset the TB, you just need to turn the key in the on position and leave it there for 3-4 mins
Old Mar 29, 2006 | 12:51 AM
onepoint8tee's Avatar
Youll need to reset power windows so the 1 push- auto down/up feature works again..
Old Mar 29, 2006 | 01:01 AM
KarlMarx's Avatar
ORIGINAL: onepoint8tee
I notice that whenever I disconnect the battery on mine, I have to wait about 30 miles or so, before the 1 touch will start working again, but it comes back automatically "with a mind of it's own..."
You have to manually reset the B5's?
cwedholm1
Mar 30, 2010 04:30 PM
shayrgob
Oct 3, 2008 09:17 PM
millenia
Sep 25, 2008 09:22 AM
eliTTe
Mar 21, 2008 12:01 PM
a4sport
May 17, 2006 03:10 AM
