DISCONNECTING THE BATTERY.
Hi, I just wondered because my battery is 'on it's way out' is it safe to disconnect it and replace it with a new one? just i read somewhere doing this would reset certain settings within the cars electronics and compuers, thanks for your replies
Yeah it will reset the radio most likely. Make sure you have the "safe code". It is typically located in the owners manual. Also the car may run rough for a few hundred miles while the ECU readapts.
ORIGINAL: onepoint8tee
Youll need to reset power windows so the 1 push- auto down/up feature works again..
You have to manually reset the B5's?
