Display LED going faded
Old May 13, 2004 | 11:20 AM
robz's Avatar
Default Display LED going faded
Has anyone had the LED display going faded so it can hardly be read in daylight?, (the one on the centre console showing fuel consumption,outside temperature etc)
Can anything be done about it, except getting a replacement for £400.......
Old May 13, 2004 | 12:57 PM
ImolaS4's Avatar
Default RE: Display LED going faded
Honestly never heard of it fading before. It sounds like an R&R type deal - usually those sorts of things are one piece and aren't worth the effort of taking apart to fix. Maybe you can get the part and do the R&R yourself.
Old May 13, 2004 | 01:24 PM
clconversion's Avatar
Yes I have seen that a lot probley once a week a car comes in with a fadded DID (driver information display) and the tech will just replace the whole unit I just hope your car is still under warrenty that instrument cluster is ushally around $900.00 canadian
Old May 14, 2004 | 01:09 AM
jditten's Avatar
My display is starting to get lines through it a bit. It's really not a necessity it's for show and if you want to shell out some $$ then get it repaired but other than that forget it.
Old May 14, 2004 | 01:36 AM
Jestnomen's Avatar
6th Gear
i just purchased an instrument cluster off ebay a couple months ago for $100US. The odometer can be rolled forward one time with a VAG-Com. That's an option for you. If you are really technically gifted you can buy a used one and remove the display. There have been some posts on audiworld about this.
Ribo21
Aug 25, 2009 02:10 PM
david9999
Jan 27, 2008 11:51 PM
intastella
Aug 6, 2007 09:18 PM
boxrocket
Apr 25, 2007 05:27 PM
david9999
May 24, 2006 01:34 AM
