Diverter Valve
Not positive where the b7 one is. I would assume they didnt move it too far from the previouse ones. Luckily you have the new diverter valve so you know basically what it looks like. I suggest untill someone with a B7 confirms where it is you try and look where they are typically on older models which is under the turbo like you said before. Its easyer to jack the front of your car up and remove the skid plate. After that it should be fairly wide open if its like mine. Here is what the DV should look like:
Hope this helps
Hope this helps
its not how it looks its what it does a BOV vents to atmosphere which ***** up the cars thinking and makes it run like **** and ***** the cat, a dv recircualtes back to the car so the metered air isnt vented
my post was really meant as a joke. But after reading Badluckaudis response, I would like to know more about the dv. It sounds like a BOV is just for sound but a dv does somthing performance wise. is this correct. And what is meant by metered.
FtMyersAudiFreak
May 25, 2005 11:35 PM
