DIY - Secondary air pump???
Old Oct 10, 2007 | 09:00 AM
damir21's Avatar
Default DIY - Secondary air pump???
anyone got any steps to replace the secondary airpump, and the coolant fan cm
Old Oct 10, 2007 | 10:27 AM
acetrebo's Avatar
Default RE: DIY - Secondary air pump???
Well, its straightfoward.
Remove airbox. Remove and replace air pump. Replace airbox. there is not much to it, so I doubt there will be a writeup.
You may find a write up for removing the airbox if you search.
Old Oct 10, 2007 | 11:02 AM
techbod's Avatar
Removing and installing secondary air pump motor -V101-
If fitted, detach cover -1- on right of engine compartment.
Disengage solenoid valve 1 for activated charcoal filter system -N80- at air duct.
Unscrew bolts -arrows-.
Remove air duct -2-.
Unplug electrical connector -3- at solenoid valve 1 for activated charcoal filter system -N80- and the electrical connector -5- at air mass meter -G70-.
Detach hoses -1-, -4-, -6- and -7-.
Remove fastener -2- and detach air cleaner housing.
Unscrew the two bolts (accessible from above) from bracket for secondary air pump.
Vehicles with auxiliary heater: remove bolts -arrows- securing exhaust pipe for auxiliary/additional heater to noise insulation.
Release quick-fasteners -1- and -2- and take off front noise insulation.
Unplug electrical connector -3-.
Detach air hoses -1- and -2-.
Unscrew the bolts (accessible from below) from bracket for secondary air pump.
Detach secondary air pump motor -V101- with bracket.
If necessary, detach secondary air pump motor -V101- from bracket.
Installing
Installation is carried out in the reverse order; note the following:
Note[/align]
Secure all hose connections with the correct type of hose clips (same as original equipment) .
Tightening torques
Component
Nm
Secondary air pump motor -V101- to bracket
10
Secondary air pump bracket to body
10
[IMG]local://upfiles/12092/3DF8657B112B4F878CA15A98AF5FAD68.jpg[/IMG]
[IMG]local://upfiles/12092/2D4B47D5C3624C488D0C5F90585CCAA0.jpg[/IMG]
[IMG]local://upfiles/12092/FB64F00DAEC24E4F84E2C37CB2CCA5F0.jpg[/IMG]
[IMG]local://upfiles/12092/E4A5D3F2741A4AB294F7C2914C99E4DF.jpg[/IMG]
[IMG]local://upfiles/12092/7DB462D450EB4553923EB3A62FC75A4D.jpg[/IMG]
Old Oct 10, 2007 | 12:48 PM
damir21's Avatar
i have an carbonio intake on it, so i think it might be even faster, is it easier to remove it from under the CAR?
Old Oct 10, 2007 | 12:57 PM
techbod's Avatar
that's the idea ( from under the car ) the pictures show you how
Old Oct 11, 2007 | 10:13 PM
freedom's Avatar
What dose this do performance wise if it's bad?
Old Oct 12, 2007 | 10:26 AM
sineo's Avatar
ORIGINAL: freedom
Not a lot.
boostedboot
Dec 13, 2011 11:10 PM
jeeps5
Sep 22, 2011 06:01 PM
Reiem125
Mar 15, 2009 02:31 AM
moeron7
Nov 29, 2007 06:03 PM
