Downpipe help!
Old Sep 28, 2007 | 02:58 PM
AudiBama's Avatar
Default Downpipe help!
im lookin at this downpipe:
http://www.ecodetuning.com/shop/cart...tail&p=670
would that suffice?
they claim 40fwtq and 10-15fwhp but im sure thats grossly overestimated...what kind of gains would i be looking at w/ an aftermarket downpipe? (i already have exhaust)
Old Sep 28, 2007 | 03:14 PM
acetrebo's Avatar
Default RE: Downpipe help!
That will do.
What turbo are you running? It should make 10hp on stock turbo, more if BT.
Old Sep 28, 2007 | 03:17 PM
qUaTtRoA4's Avatar
looks good, I'd def go for it...Im guessing since you already have exhaust, my guess would be that you could add 10-15 wtq...
well, gl!
Old Sep 28, 2007 | 03:23 PM
AudiBama's Avatar
yeah stock turbo....plans are downpipe, tune (when i get more cash), and then carbonio intake when i go through my engine dress up phase, then coilovers, tint, wheels etc
Old Sep 28, 2007 | 03:49 PM
A4speed's Avatar
carbonio intake is only for looks, it doesn't really add any hp. for the money it might not be worth it, i had mine put on and it did not do anything performance wise.
Old Sep 28, 2007 | 07:12 PM
AudiBama's Avatar
is it worth the extra money for the injectors for the stange 1+ tune from APR?
Old Sep 29, 2007 | 03:28 PM
Adam@mvp's Avatar
The downpipe looks nice and Im sure that it will make good power but will it fit your turbo? Be sure that it will fit the back housing of the turbo before you purchase it and that it was made on the car. Dont want it hitting the firewall, I know that can happen because its happened to me when making them on a JIG.
Goodluck,
Adam~
Old Sep 29, 2007 | 03:31 PM
Adam@mvp's Avatar
On the injectors, it all depends on what you plan on doing with the car. When you do larger injectors that means you are needing to add additional fuel for the extra boost and HP that you are needing to make. Are you just going to chip it with the stage 1 then be done or are you getting say a GT2871R or larger? Stock turbo then no, larger turbo then yes.
Adam~
ORIGINAL: AudiBama
Old Sep 29, 2007 | 03:43 PM
PandaXpress's Avatar
i say a test pipe (thats not a down pipe likeu said) is a good cheap upgrade
but u'll never pass a smog test again and is illegal in most states
but i say u should get a nice exhuast system wit a down pipe to help use its full potential
if your gonna go APR stage 1+ (performance chip with the larger injector programing) i say a test pipe will help alot, but remember u will also need a FMIC and other stuff, they say APR statge 1+ is like getting chipped again
i say you should just start off wit a regualr chip then when ur bored upgrade to stage 1+ wit the larger injectors and programin becasue most shops let u up grade the programmin for cheap and all u have to do is buy the injectors from them
mattrazzo
Feb 20, 2011 03:44 PM
stefano5
Jul 18, 2008 12:37 PM
nvus1too
Mar 25, 2007 02:39 AM
EliteTuning1
Nov 30, 2006 06:48 PM
MeanAudiA6
Nov 21, 2006 02:54 PM
