downpipe install
Old Dec 7, 2004 | 02:19 AM
trailboss's Avatar
Default downpipe install
Well i started removing my old downpipe as my new one arrives tommorrow, and it is such a bitch to remove. I have a 99 1.8t FWD A4, quattro is deffinately different in the downpipe install as far as space. Has anyone with a FWD installed a new downpipe, any hints or tips. I got one bolt off and the other two i broke loose but they are so hard to turn now. The problem is room, there is none of it. I am considering cutting the bolts off because I am recieving new ones with the new downpipe. Any help would be appriciated.
Old Dec 7, 2004 | 02:33 AM
David_K's Avatar
Default RE: downpipe install
use penatrating oil.
Old Dec 7, 2004 | 02:38 AM
trailboss's Avatar
I did..... I think im just going to cut them tommorrow, its easier and i have new ones that come with the downpipe. Its so f-in cramped in there, im actually doing most of the work from the wheel well, not underneath thats how bad it sucks.
Old Dec 7, 2004 | 02:41 AM
David_K's Avatar
rent a compressor from autozone and rentan impact wrench and a air ratchet
Old Dec 7, 2004 | 02:46 AM
trailboss's Avatar
I thought about it, but i can barely fit a hand and a wrench in there to have working room.
Old Dec 7, 2004 | 02:58 AM
David_K's Avatar
you gat an extention. believe me with an impact the bolts will come off in a second. and what happenes if the bolts get stuck in your manifold?
Old Dec 7, 2004 | 03:03 AM
trailboss's Avatar
how would that happen, it would have to go through the CAT, besides they are on the outside of the CAT. I might give the air compressor thing a try b/c ive been wanting to get one, so now is a good time to.
Old Dec 7, 2004 | 03:27 AM
David_K's Avatar
no if you torch the bolts off ot break them off what happens if they get stuck in you manifld. (broken that is)
Old Dec 7, 2004 | 03:54 AM
04a4's Avatar
that happened when i replaced the exhaust on my mustang
just use lots of wd40 and if you have a floor jack, used the handle and put it over the socket wrench to get more leverage w/extentions of course
At least it worked for me.
vtraudt
Apr 30, 2014 08:17 AM
mattrazzo
Feb 20, 2011 03:44 PM
71custom
Apr 15, 2009 06:48 PM
gixxerryder
Oct 23, 2008 06:09 PM
quattro411
Oct 28, 2007 07:30 PM
