drain gas **please help**
So i borrowed my friends 2005 audi a4, and i filled up the car with 89 gas, as that is all the station has. The car died, and i need to get all the 89 gas out and get some 91 gas in. does anyone know how i can drain the gas out of the car?
thanks in advance
thanks in advance
the gas is not the reason for your car to die,but if you want to drain it open the trunk remove carpet remove cover{3 scrues} remove outlet hose atach extention place it in the can remove cover for fuse box remove fuse for fuel pump aplly power to inlet for fuel pump it will activate pump and that is it there is no other way
Yeah... our cars will run on 87 octane... Sometimes people are forced to buy it in a pinch... some of us keep bottles of octane booster in the trunk, just for such situations.
So yeah... you should figure out why the car actually died. Any check engine lights?
