DV
Old Sep 1, 2006 | 06:32 PM
chaos92287's Avatar
Default RE: DV
so should i also upgrade the waste gate if i get a 007 or no?? also are there any performance differences between the 006 and 007 or is it just the size?
Old Sep 1, 2006 | 06:37 PM
InsaneHatter's Avatar
Default RE: DV
there is no performance difference between most dvs.. maybe throttle/boost response.. but hardly..
your not changing the wastegate, your changing the electronic acuator (n75h).. you can change it if you want, its all up to you if you want more boost,
Old Sep 1, 2006 | 06:43 PM
onepoint8tee's Avatar
Default RE: DV
Stock as in the original equiptment that came on my a4.
Old Sep 1, 2006 | 06:52 PM
chaos92287's Avatar
Default RE: DV
thats what i meant would changing the wastegate provide more boost or any significant performance gains?
Old Sep 1, 2006 | 09:11 PM
Jeff's Avatar
Zombie Defense Force
Default RE: DV
dont change the wg becuase if you hold more boost and run more boost then you need a tune for that. otherwise....death
Old Sep 2, 2006 | 12:09 AM
Drunken Badger's Avatar
Default RE: DV
Quick question on the subject of the 710N. This morning i replaced the stock DV with the 710N, ( did this while changin oil, kill two birds with one stone). roughly 2 hours later the MIL (malfunction indicator light) popped on and hasn't shut off. Drove around a bit and the car seems to be running absolutely fine. Will check the hose clamps tomorrow just to make sure they are on tight enough. Car details listed below
99 a4 1.8t quattro manual
No modifications except for the following....
710n (primary reason for replacement was i bought this car used almost a year ago, has roughly 94k miles on it now and figured id replace it before it went bad whilst doing regular maintence on the car)
larger capacity oil filter
resonator and mid-muffle delete.
I wouldnt think that the removal of the mid-muffler and resonator would set off the O2 sensor seeing as it is past the cat... Note* Car is not chipped; Friend states that the new dv requires higher psi to operate, but from using the almighty search function and reading up i was coming to the conclusion that it doesn't require more boost, yet just is stronger and able to handle higher psi levels. Am I correct in my evaluation?
Old Sep 2, 2006 | 01:15 AM
18T's Avatar
18T
Default RE: DV
ORIGINAL: InsaneHatter
buy a 710n and call it a day, max $45 from the dealer.
dont jump to conclusions so fast. at some dealers its 70$ +tax
Old Sep 2, 2006 | 01:58 AM
  #18
BaconBait's Avatar
Default RE: DV
ORIGINAL: Drunken Badger
Changing the dv shouldn't cause the CEL (check engine light) to come on unless one of the hoses is disconnected. Get it scanned for fault codes. Autozone does it for free.
