DV install help
Old Dec 6, 2007 | 10:22 PM
McGovs2.7TB5's Avatar
Default DV install help
I just got my forge 007 in. I thought I read that it needs to be greased before I install and every year or so after? I couldnt find the info in a search and know how to install just need to know what grease (if any).
Thanks.
Old Dec 6, 2007 | 10:32 PM
cincyTT's Avatar
I'm make believe
Default RE: DV install help
its ready to install. Greasing it once a year is fine, many dont ever do it. To do it, just remove the top and pull out the piston and apply some high temp grease on it and then reinstall.
Old Dec 6, 2007 | 10:42 PM
Cool. Thanks.
Old Dec 6, 2007 | 11:23 PM
chaos92287's Avatar
i never greased my 006 and never had problems with it.
Old Dec 6, 2007 | 11:39 PM
cstarky15's Avatar
i have a 007 and never greased it. just put it right in. the one time clamp on the OEM one is a pain to get off tho.
Old Dec 7, 2007 | 01:52 AM
Bogie's Avatar
Jack up the car on the passenger side and go at it from underneath. This took me all of 10 minutes to remove the stock and install the Forge 007P DV. use a flathead screwdriver to help pry off the vacuum line, or else when you pull on it, the vacuum line acts like a chinese finger trap/ chinese handcuffs - not meaning to be non-politically-correct - but I don't know how else to describe it.
Old Dec 7, 2007 | 09:54 AM
sweet. thanks for your help fellas.
Grey2007
Feb 23, 2012 01:17 PM
kevinbednarek
Feb 22, 2012 06:19 PM
Brautty
Jan 21, 2012 12:38 AM
Dave666
Jul 12, 2005 08:47 AM
1996a4
Apr 4, 2005 04:09 PM
