DV install question
Old Jan 15, 2008 | 10:45 PM
mbertoli's Avatar
Default DV install question
this has probably been touched on more than a few times; tried searching for it but with no success.
2001 a4 1.8T
i just bought a forge DV and installed it. noticed that on the forge, there is a small opening on the top of the DV, whereas the stock one is just flat on top.
so can i just plug that hole up? or should i hook a vacuum line up to it?
- Micah
Old Jan 15, 2008 | 10:56 PM
Bogie's Avatar
Default RE: DV install question
Same as stock dv - there should be a small vac line that runs from the top of the DV across the front of the upper timing belt cover, over the alternator, to a nipple under the intake manifold, right by the oil dipstick tube. The other two larger hoses go to the same locations as the stock dv setup as well.
Old Jan 15, 2008 | 11:16 PM
mbertoli's Avatar
ok, but my stock DV did not have that top nipple for the vacuum line.
did the PO do something weird, or the vacuum line not really necessary?
Old Jan 15, 2008 | 11:31 PM
TeeterTawter's Avatar
you kinda need it,heres the diy. http://audizine.com/forum/showthread.php?t=17369
Old Jan 16, 2008 | 08:57 AM
Bogie's Avatar
ORIGINAL: mbertoli
Then you did not remove your dv, that was some other valve. The dv is below that one, so put that one back where it was.
Old Jan 16, 2008 | 11:14 AM
chaos92287's Avatar
ORIGINAL: mbertoli
every dv has a vacuum line at the top. you sure you didn't remove the 034 valve from the TIP? it kinda looks like a dv without a vacuum nipple on top.
Old Jan 16, 2008 | 12:53 PM
mbertoli's Avatar
yeah, you're right!
i removed the 034 valve.
wow, i'm glad i haven't driven my car since the install!
thanks for the help.
M
Old Jan 16, 2008 | 01:40 PM
feerocknok's Avatar
Yup, been there before. The DV is too big to fit in those holes anyway, so it's kind of idiot proof.
Old Jan 16, 2008 | 02:00 PM
mbertoli's Avatar
haha, you'd think so, but i just pushed hard and it fit! guess i should have known.
ahh, the trials of working on a new car...and being dumb. thank goodness of the internet!
Old Jan 16, 2008 | 02:24 PM
chaos92287's Avatar
lol yeah, your not the first who's done that
Pbcrazy
Jun 5, 2013 04:56 AM
1.8_Turbo
May 23, 2012 06:37 PM
cantdrive55
Jul 26, 2008 09:59 PM
mikejda
Apr 7, 2007 09:26 PM
krue92
Jul 26, 2005 06:56 PM
