question on HFC install....
Old May 22, 2012 | 11:06 PM
1.8_Turbo's Avatar
Default question on HFC install....
so i know a few of you guys on here are running a 034 HFC, so my question is
-How did you tighten the cat to turbo nuts?? You can’t go at it with the socket because there is no room between the bigger diameter piping on the cat and the side of the nut, and a wrench doesn’t fit in those areas.
Thanks guys
Old May 23, 2012 | 12:43 AM
1.8_Turbo's Avatar
Nevermind! did a bit more digging and found out they use different nuts.
Old May 23, 2012 | 10:59 AM
MetalMan's Avatar
How do you mean by different nut?
The normal OE-specified nuts to hold the cat to the turbo require a 17mm socket/wrench. As you found out they are the biggest pain in the *** EVER to tighten/remove (I used to remove and install the turbo and cat together).
Just in case others want this information, I now use these nuts:
Home Page > Search > 18301737774 > ES#40452 Hex Nut - Priced Each - 18301737774
If you search that same part number on AutoHausAZ they cost half as much... Anyways, these nuts use a 15mm socket/wrench which definitely fits. I've got the FrankenTurbo exhaust manifold, and that makes the nut closest to the exhaust mani even more challenging to get at and these nuts do the trick (and a swivel + 3" extension takes the cake).
Old May 23, 2012 | 06:37 PM
1.8_Turbo's Avatar
sry, just different in that its a 15mm rather that a 17mm, thats for the reply tho! this helped me out tremendously
Pbcrazy
Jun 5, 2013 04:56 AM
cantdrive55
Jul 26, 2008 09:59 PM
mbertoli
Jan 16, 2008 02:24 PM
mikejda
Apr 7, 2007 09:26 PM
krue92
Jul 26, 2005 06:56 PM
