dv valve
Old Aug 17, 2005 | 01:15 AM
juice88's Avatar
Default dv valve
does a dv valve make the sound of a bov?
Old Aug 17, 2005 | 01:20 AM
PandaXpress's Avatar
Default RE: dv valve
no they dont casue the air goes in the the intake instead of blasting in to nowhere
Old Aug 17, 2005 | 01:23 AM
Toff_the_Toffee's Avatar
Is a DV just a US name for a recirc valve, or is it different? If it is, then it will make a BOV noise, but it depends a lot on what induction set up you have. Regular airbox, then you will probably hear it very little, if at all. On a cone filter, ro similar setup, you will hear it more. I could hear the stock dump valve on mt MR2 Tubby as much as the BOV that I fitted afterwards, due to the HKS filter I had installed.
If a diverter valve is not a recirc valve, than I am probably talking bollox!! (we call things different things in UK than over here!)
Old Aug 17, 2005 | 01:35 AM
juice88's Avatar
the only thing i have to worry about now is finding a place in my area that will install peformance parts and hopefully they wont charge alot but do u have any idea of what the cost of a dv installation would be?
Old Aug 17, 2005 | 01:37 AM
germancarmaniac's Avatar
do it yourself. its one of the easiest things you can do to your car.
Old Aug 17, 2005 | 01:39 AM
its not the easiest
if u have a lift it would be easier but its not the easiet thing to do
http://awe-tuning.com/pages/info/awe...dow.cfm?FAQ=30
Old Aug 17, 2005 | 01:40 AM
juice88's Avatar
well see i have no mechanical experience ata ll so i dont think i could or should for that matter
So is a DV just what they call a recirc on this side of the pond?? I'd like to know so I can put it in the file listed 'Audi stuff' in my head...
Old Aug 17, 2005 | 01:46 AM
do it yourself. Its super easy. maybe a 30 minute installation at the tops.
Old Aug 17, 2005 | 02:33 AM
lidonnit's Avatar
No body wants to talk to Toff anymore??? Anyway Toff, yes it a recirc & DV are the same. As for the original question... yes you can purchase a DV that sounds like a BOV, but generally they don't at all.
