Easiest Way to Replace Headlight Bulb
I know it sounds dumb but I am swapping out the high beam bulbs on my 2001 and it looks to me like you have to remove the entire headlight assembly to get to the bulbs? Am I right in that I have to remove the torx bolts out and then replace the bulbs? Sorry if its an easy answer.
No, the drivers side is simple. Remove the cap and the bulb is held in by a clip on the inside. To get to the cap on the passanger side you just have to remove the air box ducting.
